Besides fitting and wiring the cylinder baffles in place and fitting the muffler so that I can determine where the exhast pipe should be located, I also joined the front sections of the two ram air ducts with 5 minute epoxy and placed an aluminium strip under each for a little support. Will add some photo's tomorrow.
Right side baffels wired in place
Left baffels wired in place
Muffler fitted, this was a real tight fight and a bit of a struggle to get on
