Daves Web Site
Date:  8-9-2016
Number of Hours:  10.00
Manual Reference:  13-11
Brief Description:  Nose Top pins 2
Over a couple of days or cure cycles I've edged out the tubes and inner wire so that they line up perfectly. I've routed down a little where needed to reduce the amount of bending the wire has to do. A bit of sanding as usual was needed to get the tubes to sit tightly in the grooves.
The micro I've used is really dry to reduce weight. I thought about using foam instead and then micro but really this is stronger and the amount of fiddling would be out of control for very little gain. If I have to spend extra time I like to see something for it.
Finally everything was lined up and ready to see if it was all good after the cure...
Mid section tubes
Mid section tubes
Forward hatch tubes
Forward hatch tubes
Full length tubes in place
