Brief Description: Right Winglet bottom skin cleanup
About three hours work just to clean up the edges of the right wingtip. Of course I was really careful on the leading edge sanding down to the plastic tape and then very gently so I wouldn't damage the blue foam. It just takes a while. It worked out OK as you see in pic 2.
In pic 3 you can see my wingtip edge and this is going to work nicely with a fox corner to come.
As it turns out it was only early afternoon and the room was still warm so I went ahead with the other winglet. This log limits daily entries but trust me it was a long day.
