On to the Left hand wing cores. Most of the prep work is done here. Its time to join the two FC lower wing blocks together.
I used the straight edge to keep the shear web area flat then my clamping jig and a few pins as usual. I get things as straight as I can but its not perfect.
I hope to sort all this out by shims and bondo as required to get the cores straight before the shear web, caps and skins go on. For now they are close, and glued together.
