Brief Description: How to setup Wing Core and CS Spar positions 8
This is a relativeloy easy step, there had to be at least one!
FC1 is just a bit short due to it being trimmed with that wedge taken out to fit the main wing correctly and match the CS spar. I just found a scrap of foam and got it to the right thickness.
Then it was easy to glue and pin it in position (pic3). I later trimmed the edges and will do a final trim before any glass layups. Its pretty close to the right size for FC1 now.
This will all be removed later and is just a former for the glass to glass area. I wanted the sizes veryy close in case it was an issue in determining wing bolt holes later. I can just use the plans sizes now.
