Daves Web Site
Date:  1-5-2014
Number of Hours:  10.00
Manual Reference:  19-4
Brief Description:  Joining LH Wing upper Cores
The first pic is just a reminder of where the hard points are on the spar relative to the wing FC1 core. Thought I'd better stick in a pic with a ruler somewhere! I hope to maintain those lines despite sanding and so on along the way in case its useful later.
Pic 2 shows the LH upper wing cores going together. I used a bit of the packing foam to help the clamping.
Now I am ready to lay out the floor again, but for the LH wing so I can get it all lined up and find where FC1 needs to go. Its a bit of a proceedure but good to do it now while the benches are moved and its fresh in my mind.
I am thinking about where the wing cores are going to be stored!
FC1 CS spar hard point marking
LH Upper wing cores
LH Upper wing cores
Busy workshop area
Busy workshop area
