Daves Web Site
Date:  6-30-2013
Number of Hours:  10.00
Manual Reference:  9-3
Brief Description:  Axle template cutouts
Once I had the pads lined up with the marks on my window 26 feet away I knew the plywood bases were in position. A lot of Bondo or builder bog was carefully applied all over the place to ensure the template pads were not going anywhere.
I tried routing things sideways but soon realised I needed to turn the fuselage on its side to get a good job. I did this carefully, its getting to heavy for one person but no one else was around.
Once one side was done, I rolled it over again and did the other side. ...well, it took all day but I have my complex flats routed out finally.
Laser lineup bogged
Laser lineup bogged
Routing position
Routing position
Axle pads done
Axle pads done
