The first pic shows the flat axle mounting pad with an interesting pattern relating to the curved layup. I used a different epoxy for these pads too. One with a higher TG than usual given these pads may get hot with braking.
Pic two is checking camber just using a spacer block. Its all good.
Third pic is my first attempt to mount the lasers again, this time on the axles to check toe in. I tried a few things after this. You have to start somewhere. I ended up inlaying a bolt head so that I could do the platforms without spacer washers. This made the lasers more stable for checking things.
