Darrel's Kitfox - SS7
DEW2
Exhaust install
Located and cut the exhaust pipe pass thru hole
Located where the exhaust pass through hole in the lower cowl should be and, via a series is iterative cuts, cut the hole.
Also, started designing where the oil cooler will be mounted.
Exhaust pipe thru the cowl
H-5 Home
DEW2 Home
3012
Basic Kit
211
Fabric cover
82
293
Final assembly
701
Inspection
Kitfox Avionics
Kitfox tooling
Kitfox Undercarriage
Kitfox wings
Lighting
88
Modifications
Paint System
87
335
Tooling
Tooling
Undercarriage
