Darrel's Kitfox - SS7
DEW2
Large baffle
Fabricated parts for the large baffle
Located the raw material for 2 reinforcing plates and 2 hangars used on the large engine baffle and fabricated them.
Cut from raw stock what I believe will be pieces of foam rubber that are used to seal the radiators to the baffles.
Drilled the mounting features on the jury strut brackets.
Also, passivated two hangars used in the engine ring.
H-5 Home
DEW2 Home
3012
Basic Kit
211
Fabric cover
82
293
Final assembly
701
Inspection
Kitfox Avionics
Kitfox tooling
Kitfox Undercarriage
Kitfox wings
Lighting
88
Modifications
Paint System
87
335
Tooling
Tooling
Undercarriage
