Received an order from Wicks and continued making firewall openings. Installed the manifold pressure fitting, and the Throttle passthrough. Also changed out the fuel fitting to steel. Ordered two ANL60 fuses and mounting blocks to add to the firewall. Getting close.
Manifold Pressure line will connect to this fitting.
Painted alum spacer with engine paint..
Spherical steel grommet will hold the throttle cable. Also note steel fuel fitting.
