Finished the pilot side fore and aft tiedowns. I like where the aft ones are installed because when you remove the spring loaded rings, the permanent base mounts do not project into the baggae area. They nest in the valley between two rear wall stiffener ridges. For the forward attachment, just like with the smoke tank on the co pilot side, my Bison bag needs to be clear of the attachment too. It all is good.
Mounting bolts are safely above the rudder cable travel area on both sides.
The rear baggage wall is very strong here, Many attach screws in the area.
Tie down doubler adds even more strength. Its solid. Very solid.
