Brief Description: Control cable support / Alternate Engine Ground
More miscellaneous attachments today. I added a nutplate for AN3 alternate gounding location on firewall. That location also will secure the engine breather tube on the firewall. Plans show it as an alternate grounding location. Also, fitted the bracket to the subpanel that adds support to the control cables and riveted it in place adding the adel clamps for the 4 cables coming that way.
Tested engine breather tube support.
so much for straight lines. Subpanel rivet in the way.
Contols are centered 3/4 inch to the right of centerline.
