Primed, painted and riveted the parking brake mounting bracket. After fiddling with the hose locations, I could see that I can use straight nipples on the top inlet side and support the hoses right above. I supported the hoses with an Adel clamp and after my latest order arrives from ACS, I'll connect it all. Will add nutplates to the mounting bracket for ease of maintenance.
Should have put nut plates on bracket. Using lock nuts/washers. Works, but difficult to start on.
Tape on back of 3/8 closed end wrench starts locknut in tight places.
