Marked the rear canopy frame tube mount center and drilled and clecoed skins on.Inserted canopy frame hinge into the hinge blocks and checked for .032 gap per plans. Checked to see what was causing the gap and it appears that the canopy hinge stop blocks need to be shaved a bit. Removed the stop blocks and shaved.062 and reinstalled. Still have a gap but it is better than before. Still work to be done here before I dril the center splice blocks.
