Reinstalled bolts for fuel pump and connected fuel lines Connected cabin heat cable and tested Installed Adel clamp for right side fuel vent Installed cotter pins for for rudder pedals Finished installing washers for push/pull tubes for elevator Drilled and tapped 6/32 screw hole for empennage fairing that was missing on both sides Installed wing inspection plates Installed baggage compartment panel
