Brief Description: Final fitting left side fuselage step
Bent and formed the step flange to fit flush with the fuselage. Measured and drilled the holes on the flange and clecoed for test fit. drilled anchor block holes and clamped. Drilled the holes for the block mount and had to stop and order a angle drill kit since there is little clearance to drill the holes to the baggage compartment floor rib. Will start work on the right side on the weekend.
