Brief Description: Removed Baggage floor and side skins
Spent alot of time drilling out the baggage compartment floor and side skins in preparation for installing the steps for the fuselage. This is one part of the Quickbuild that really should be optional as you need to remove about 40 rivets per side. Pop rivets were farily easy to remove. The countersunk solid rivets and countersunk platemut rivets were not as easy. All of this will have to go back once the steps are installed.
left side done, check out all of the rivest needing to be drilled out
