Brief Description: Added spacing washers to Control stick assmb
Added spacing washers to the outboard side of the control stick assembly. Made a tool to slide the inboard washer. If you notice the nut side of the assembly there is a slight bend in the mounting flange. I think I will put another washer in to provide more spacing.
