Brief Description: Fuel Pump Doubler Prime and Rivet
Sanded Doubler plate and platenuts with a scotchbrite pad. Cleaned with Acetone and spray painted with primer, two coats. Back riveted the Fuel Pump doubler plate and platenuts.
Since I had the priming stuff out I also primed the Control Stick rod.
