Rounded and shaped the two rudder fairings, drilled #43 pilot holes, matched drilled #40 holes and dimpled both skins. Clecoed temporarily in place for now. I don't think you can get the cables out once you rivet the fairings on, so I will wait until I get further along in the build process to install them permanentlly. Need to pull cables back out and insert each snap bushing along the way. This is going to be a real pain but it is the only way to do this unless you want to cut the snap busnings. They give the cables a nice touch v.s. the original plans.
