Toms RV9-A project
Date:  6-29-2013
Number of Hours:  2.50
Brief Description:  Top Coated Avionics Panel Inserts
Got my replacement Throttle and Mixture cable from Vans that are 2" longer. Removed the old cables and decded to Top Coat a few of the panels so that I do not have to remove them again. I decided to prime tha panels with Epoxy primer before the top coat as I have found that the top coat grips much better with the epoxy layer.
Prepped and primed the parts, waited a hour for the primer to set then sprayed the top coat. Tomorrow I will begin the final installation of the Carb Heat, Throttle and Mixture cables.
Panel Instert Top Coat
