Brief Description: Throttle Mixture and Carb Heat Controls
Drilled the panel for the three center console controls for Throttle, Mixture and Carb heat. The throttle cable is too short and there is no thread showing to install the nuts and washers. The Mixture seems to be ok but the curve from the center console existing the firewall coult be better.
I checked Vans website and found that they have Throttle and Mixture cables that are 2" longer that what I have. They are for the O-235 but they should work since a 2: extension is what I need. I also ordered the Mixture cable as well. I will return the other ones after I install the longer ones and make sure they fit properly.
