Brief Description: Alternate Air Push-Pull Control
Installed the Alternate Air Push-Pull control in the panel. Secured with a few adel clamps on the firewall forward side and underneath the interrmediate bulkhead. Used the steel firewall pass through fitting I made some time ago.
In the picture you can see the first ste of adel plamps above the red fuel line center of the picture and down below.
I also drilled a 1/4" hole for the alternate static and ran aft to the baggage compartment. Ordered a Y fitting to tie into the existing static tubing.
