Drilled out two AN470 rivets that were previously installed for the backrest support and riveted the headset angle. Ran wiring under the longeron rails from the avionics panel to the seat back support, drilled and installed a bushing for the headset wiring pass through. Soldered wires to the jacks and tested.
