Brief Description: Tied in Serial 1 Transponder to both displays
No pictures here.
Fixed wiring harness and ran the Serial 1 Tx line (Pin 4) to both displays. The wiring harness was run with only the Primary display connected and Dynon instructuions indicate that all serial ports must be connected in parallel beteween both displays. Somehow Stein missed this when they did the harness.
