Continued wiring the various avionics. Completed the following items: 1) Fabricated two splice blocks mounts (see below picture) that will be used for the stick grip wiring and the nav/strobe wiring. 2) Fabricated the wiring harness for Pitch Servo & ELT; Installed and tested ELT and Pitch Servo 3) Fabricated and Installed the extended wiring for the Transponder; Configured and tested ----------------------------------------------------------------------------------------------------------------------------------- Getting close to finishing up the avionics wiring here is what is left of the punch list: 1) Drill hole for ELT Coax pass through into rear baggage compartment 2) Run Pilot /Co-Pilot headset wiring 3) Flaps – Install Flap assembly in fuselage; flap switch, servo wiring and position sensor; config with VPX 4) Run pitch & Roll trim wires and install stock grips 5) Install engine and other push pull controls 6) Run Engine primer copper tubing 7) Install blast tubes for Pmags and primary alternator
