Brief Description: VP-X Bench Test Configuraiton upload
Spent some time updating my VP-X configuration as well as doing a trial run with the PC configuration software. A few glitches up front due to Windows 7 not installing specific files needed for the software. After a quick email response from Vertical Power all worked as designed.
Installed two test ground wire pins and used a standby power supply battery from my UPS to power the VPX. Upload worked fine and the unit has the current configuraiotn.
Link to my current Vertical Power Configuration can be found on the web at:
