Toms RV9-A project
Date:  10-14-2012
Number of Hours:  1.50
Brief Description:  Top Cowl sanding and second epoxy coat
Sanded down the top cowl with 60 grit sandpater and followed up with 220 grit.Blew off the dust and made a batch of very thin epoxy cut with acetone. Brushed on the final coat. I iwll do some very light sanding and the cowling should be ready for a spray primer.
60 and 220 grit sanding
second coat thin epoxy mix
