Brief Description: Mounted Transponder and UAT blade antennas
Decided to take a break from the canopy work and shifted to something easy to do. Installed Delta Pop blade antennas for the Transponder and UAT antennas. Fabricated a backing plate and drilled and mounted per instructions.
The Transponder antenna is mounted immediately behind the baggage compartmetn slightly left of center. The UAT antenna is mounted mid line in the tail. Space between the Dual Com antennas and the transponder antenna is 3.5 feet. Space between the transponder antenna and UAT antenna is 5.5 feet.
