Started with the left Aileron attachment. Reamed the holes for AN3 bolts and bolted the Aileron attach brackets to the Aileron. Bolted the Aileron to the wing and then set the neutral position per plans. Measured Aileron pushrod on both ends and compared to plans. Rods had equidistant threads showing through the witness hole.
