Brief Description: Assembled landing light bracket and outlined cover
Cut the landing light bracked 1" from the edge per instructions and dimpled and riveted together. The bracket comes ready sized for the RV7 but you need to make the bracket smaller for the RV-9. Also decided to mount the ballast to the back of the bracket. Marked and drilled three holes per plans.
Layed the paper template over the wing hole and market for the screw holes that will hold the plexiglass lens cover in place. outlined and market the cut lines for the plastic cover.
