Having thought I was done fabricating the 1/4" aluminum tube for the gear leg brake lines I moved on to my next task which was the wheel pants. After reviewing the plans for about 10 minutes I found out that I had read the plans backwards. The loop for the brake lines were run backwards. I started to look for extra 1/4" tube and I found that I had purchased Bonaco SS, Teflon coated brake lines which I totally forgot about. Cut the vinyl tape removed and reinstalled the Bonaco lines in about 30 minutes. Actually wasted about 2.5 hours the day befrore fabricating the lines v.s. looking for the flex lines. In the end, everything case out for the best.
