Brief Description: Remade Fuel & Brake Line center Console spacers
Replaced the temporary wood spacers with 3/4" UHMW. Drilled the fuel line and two brake line holes and cut in half. Tapped for 8-32 x 3/4" SS Pan head screws and countersunk. To secure the block from moving I will countersink two screws in the top each block through the top cover. This will secure the block to the top of the cover and keep things from moving. I'll do this when I get all of the wiring and conduit closer to a final installation.
