Drilled holes for snap bushings for the Pitot and AOA lines from the AHDARS through the cockpit and out to the left wing. Called Vans last week and made sure that I could drill holes in the top portion of the spar bulkhead. Van's said that as long as you don't drill through or nick the rear spar attach then everything shoulld be fine.
