Decided to hand bens where possible all of the angles for the fuel lines. Some of the curves are so tight (andair fuel line to fuel pump angle) that a hand bender does not have the necessary raidius to accomplish the task. Made a few pieces of art work before I figured out the best way to bend the tube. Ordered more tube from Vans as I need to remake the tube going from the andair fuel valve to the fuel pump. The tube needs to be offset from the bottom of the skin to sandwich between foam for protection. The bend near the fuel pump does not have the proper radius and I cannot put a spring bendor badk on the tubing. You need to get it right on one side at least so you can remove the bender. The puece in the picture below will be used as a template and I will make sure I bend the fuel pump tighter than the first time.
