Toms RV9-A project
Date:  2-12-2012
Number of Hours:  1.50
Brief Description:  RAMI Dual Com Antenna Installation
Spent some time Saturday pulling conduit in the center tunnel. Decided that using the VAN'S 5/8 corregated tube is too much trouble to pull through so I found some 5/8" O.D. plastic tubing without corregations and will finish that run later. Decided to take a break from that and do some easier work on the antenna mountings.
Drilled holes and mounted two RAMI angle COM antennas in the outer Bay aft of the the wing spar and just forward of the seats.
Dual RAMI Bent Whip COM antennas
Close up of RAMI
Close up of RAMI
