Reviewed a few builder logs and decided that I would fabricate a dual Skyview ADHARS bracket. Used Vans trim stock (.032) and made two identical support brackets.using my sheet metal bender and aviation snips. Bent an aluminum angle stiffener on the bottom and primed and riveted after pictures were taken. Next step is to level the bracket front to back and left to right using the longerons.
