I finished the Engine Breather assembly. Cut the 3/4" hose about 6" below the bottom of the firewall and used the Van's supplied swaged fitting to run the remaining distance to the exhaust tube. Drilled the whistle stop hole and bent the tube for sufficient clearance around the engine mount. You can't see from the picture but there is about 1/2" clearance from both engine mount tubes. The tube has a slight amount of flex but is quite rigid being held from the Adel clamp.
Notice in the close up image. I safety tied the wire around the neck of the tube to the Adel clamp just in case the tube moves from engine vibration.
