Brief Description: Rivet C-613 Splice plate to Wd-725 side frame.
After drilling the side C-613's to the Wd-725's sides I realized its a good idea to just go ahead and enlarge the holes from #40 to #30, counter sink and rivet the C-613 splice plates in place. Why not? So that is what I did as seen in image 1 and 2..
Now, just so you know, I've decided to hold off drilling the other side of the C-613's/Wd-725's to the forward Wd-716 weldmont until I've installed the Forward Canopy Stops, Canopy Lift Struts and Canopy Reinforcement Kit. Why? Installing any one of these affects the Canopy fit. Seems like the final angle position between the Wd—716 forward canopy frame and Wd-725side frame is key for proper canopy fit. Lets get all this canopy frame shape formers mounted before we commit the crucial angle between the forward canopy and side frame.
Also, just so you know, I'll not drill the aft Wd-725 side frame to the aft F-631 rails until the platsic canopy is fitted. Why. I'm having trouble deciding the exact position for these F-631 rails. The plastic canopy will dictate the final position of these F-631's in width and height. That’s the plan anyway.
