Brief Description: Drill C-613 Side Splice Plates to Wd-725's.
Now to drill all the holes in the C-613's forward Canopy Frame side Splice Plate. Easy enough. Mark and drill. All the holes are drilled to the smaller #40 for now. Will be enlarged later.
At this point I realized its a good idea to attach these C-613 Splice Plates to the Forward end of the Wd-725's now while they are on the bench. Center them up, match drill through the Splice plate into the Wd-725's.
