Brief Description: Adjust Fuselage Seal Flange to Canopy Frame.
As the plans state, after the Canopy Frame Goose Necks are drilled and the bushing pressed to fit you put it back on the fuselage and check for interference between the Canopy Frame and fuselage Seal Flange. Yep, I had interference. Basically, you mark the interference location on the seal flange. Remove the Canopy Frame, file away on marked locations, reinstall the Canopy Frame and try again. It's a very iterative process. I must have had the Canopy Frame on and off 6 times or so.
