Brief Description: Drill C-704 SPlice Plate to Aft Frame Channel.
Once the Aft Canopy Frame C-704 Splice Plate and “No Flange” Template are drilled, you drill one side of the Splice Plate to one of the channels. Then, much later on I'll use the “No Flange” splice Plate to drill the holes in the other channel. Image 2 shows how I'll use the “No Flange” Splice Plate later to drill the holes in the other channel.
