Brief Description: 3. Fabricate flap center bearing block.
I’ve used my little lath to drill all the holes in all the bearing blocks. Does a great job compared to what I imagine the drill press would do.
I also used it to cut the 1/16” deep groove. Finally cut it in half with the band saw. So far this part is acceptable. The problem that caused me to remake it is coming up.
