Brief Description: Flap - Buck rivet flap main spar to skins.
Next we need to buck the span wize row of rivets on the top side of the main spar. Again the tungston bucking bar worked great. You can see in image 1, I taped a small spacer under the bar to help me guage the angle of the bar to the rivet. I also added some protective tape under the bar at the end thats doing the bucking so as to not damage the spar web. Worked great. Fast perfect riveting here.
Image 3 is just the result of todays riveting. This table top is normally totally clear when I start a task.
