Eds Vans RV-6A/7A Web Site
Date:  12-17-2008
Number of Hours:  0.00
Brief Description:  Flap - Enlarge for rod end bearing.
The hole I'm pointing at in image 1 has to be enlarged to 1/4" I used 2 different step drills for this. The first one has more steps but the steps are shorter then the thinkness being drilled. I figured that this mico stepped bit would cut a better hole by gradually opening up the hole. Once I hit the 1/4" step I switched to the second bit that has steps that are long enough to go through the hole. For me, this worked great. Smooth perfect hole that did not shift.
This hole gets enlarged.
First bit enlarges hole.
Second bit finishes it.
