Eds Vans RV-6A/7A Web Site
Date:  10-9-2008
Number of Hours:  0.00
Brief Description:  Rivet aileron hinge brackets.
Here they are. Aleron hinge brackets riveted up.
Special attention needs to be spent on keeping -
The parts together.
Which holes get counter sunk.
Rivet direction.
You actually use a rivet length of 11 on these guys.
I found that using the thin 1/8" universal set and thin flat set made it possible. I don't thing I could use my squeeser to rivet a length 12.
Length 11 seems to be the maximum. Anything longer then 11 needs to be bucked.
Notice the unprimed polish look. I did prime the mating surface of the angle stock however.
Ready to be mounted to rear spar.
Notice flush rivets.
These were fun to rivet.
