Brief Description: Fit problem with the aleron hinge brackets.
Aleron hinge brackets. These guys are interesting in that you have to match up all the parts and then identify which holes are counter sunk for flush rivets. The kit came with a separate 2 sheet, 8.5"/11" drawing to help get these things put together correctly. It also has the rivet call outs.
Notice the small gap near the top skin between the angle stock and the rear spar. Just use your scotch bright wheel to adjust the angle stock to get a flush fit.
