Eds Vans RV-6A/7A Web Site
Date:  9-1-2008
Number of Hours:  0.00
Brief Description:  Leading edge joint plate, Part2.
I worked out a procedure to attach the joint-plate plate-nuts with precision.
All #8 dimples are done. Don't dimple the holes attaching to the rib yet.
Cut a #8 screw real short to help hold the plate-nut steady and in position for both drilling and riveting the plate-nut attach holes.
1.) Attach plate nut with short #8 screw and tighten. Use a cleco clamp on the plate-nut wing to keep the plate-nut from rotating while tightening the #8 screw.
2.) Drill one plate-nut attach hole, counter sink and rivet.
3.) Drill the other plate-nut attach hole, counter sink and rivet.
I would not remove the plate-nut after drilling the plate-nut attach hole to debur or anything. Just move right to the counter sink and rivet.
This procedure does 2 important things.
1.) The plate-nut is perfectly centered.
2.) The plate-nut attach rivets are perfectly flush.
When you're done, you can flex the joint-plate in a curve and see no distortion.
Shourt #8 screw for plate-nut attach help.
Drill, CS and rivet one hole at a time.
A couple nut-plates completed.
