Fourth, remove the leading edge, leaving the inboard leding edge rib attached.
Fifth, Quick, put a couple of clamps (Picture 2) on the tank outboard rib to hold the tank in position left and right. If the outboard tank end moves, it will no longer alaign with the joint plate.
Sixth, remove the joint plate and leading edge rib (picture 3).
